PCBs into 2U rack - can I omit 3PDT (for always on)/LED and still work?
Stupid question and I assume the answer is yes, but figured I would ask:
I have a bunch of pedalpcb boards all populated and was going to put them in a 2u rack enclosure with regular in/out and power. I was going to omit the LED and the 3PDT so they're always on. I was going to use an external switcher and patch bay to put them in and out of the signal path.
Will these boards run without a switch?
I figured they would but I just got a Low Tide Modulator that has a breakout board with it. From what I could tell it seemed like I could do the always on thing with it, but I'm not sure. With it being attached to the main board makes me question it. Like, assemble the bed and have a bag of bolts left over that say "load bearing"
I've built a ton of stuff, but I'm more of an assembler and avoid straying from the set layout typically. Pretty sure this would work, but also except the answer could easily be, duh of course this won't work.
Thanks,
Pat
Thank you - that's what I figured, but wasn't sure if there was something I was missing.
When I saw the Low Tide Modular breakout being attached, wasn't sure if it was because it's necessary, or just that it's a six hole instead of the usual four which seems is the case. Made me start to second guess everything.
The build doc also has a wiring guide for that, but the six holes are because the jack in/out are on the board itself in that one (due to space I guess), so that's the two extra pads. You could skip the extra pads and wire it straight from the jack instead, similarly to other pedals.
I guess buffered boards are also slightly different, but since it's going to be always on you can just ignore the buffer part and wire it like true bypass instead. Not sure if every buffered board (which there aren't that many I believe) has instructions on how to do it, but at least it's on the forums somewhere.
So trying to understand this for future use. if I want to leave the foot switch out and have the pcb always on, I can just run the in and out pads directly to the jacks? What then happens to the ground and sw pads?
Nothing. The 3pdt switched gnd to the led and input. If it's always on, you can just leave them unpopulated if you're not using the pad on the main PCB. If you are, jumper them.
