DEFX Pretty Tears
Cybercow
The DEFX "Pretty Tears" project is (IMO) pretty spectacular. Just finished building mine (didn't rock it before boxing it) and fired it up. Bypass works fine. But when I the engaged the pedal (the LED lit up - YAY!) it made no sound. WTH???? So I futzed with the knobs & switches and got nothing. But then after about 5 minutes, the sound started coming thru. Woot! Apparently, the JAN5678 tubes take their good sweet time warming up to enough to produce the awesome sound this unit was designed to do. And WOW! What a spread of fuzz and distortion tones with sweeps and warbles depending on the settings.
Any here's the pictorial journey of the build from beginning to end . . . .
It usually starts with populating the PCB . . . .
Petty_Tears_Population_01.jpg Petty_Tears_Population_02.jpg Petty_Tears_Population_03.jpg
Then the enclosure graphics test fitting . . . .
With the graphics verified, on to applying the decal to the drilled enclosure . . . .
Petty_Tears_Decal_Setting.jpg It looks horrible while drying, turned out great in the end. Petty_Tears_Decal_Done_01.jpg Petty_Tears_Decal_Done_02.jpg
Then the stuffing and completion . . . .
Petty_Tears_Guts_Done_01.jpg Petty_Tears_Done_02.jpg Voia! a Pretty Years pedal in a 'Petty Years' package. Petty_Tears_Done_01.jpg
Thanks for looking! Happy building!
That's PHHHHAT! Inna reallllly gooood wayyyyyy...
So, to confirm something, that's a 1590X enclosure?
Were I to build this I'd want to orient it horizontally, but looking at your gutshot... not much room for jacks.
Man, your builds ... you always manage to JUST SEND IT!
Thanks Feral! Yeah, that's a 1590X box. So it could've been oriented horizontally with the added vertical height. But not within a 1590XX enclosure.
I checked another option — Hammond 1550E: 171 x 121 x 51... so taller than a 1590XX but not quite as tall as a 1590X with an extra 26mm wiggle-room on the lengthy side. I can't imagine trying to get this in 1590XX.
Not a nice graphic like the one you show, but I found this chart on the Hammond site . . .
Excellent!
Went ahead and made my own graphic based on the chart:
Excellent!
Nice! Thanks!
