Micro XLR Hookups
I've got a request to build the EMU with 1/4" and XLR out.. Has anyone completed one like this? I'd like to know the best way to wire it up to have both options..
I similarly hooked this up to the output buffer for an Empyrean Deluxe (op amp buffer, in that case).
Anyone have a stateside source for the XLR Jack used in the MicroXLR? Tayda is too long to ship for what i'm trying to do....also what sizes are the capacitors? I only have a booklet of 0805 stuff and they are larger than that..
Check post #11, it has a Mouser link for everything.
I'll check in the morning, I might have an extra one left over.
The footprints are 1206 / 1210... the good thing about SMD (by hand) is that you can get by with just about anything close to that size.
I oversized the 10u just so it'd accept a wider range of parts, but if you have an 0805 at 10u then go for it.
OK I sent you the full set of passives.
You already have an opamp for it right? I just realized I didn't put one in there but I can if you need it.
Hello everyone! This is my first post on the pedalPCB forum! I'm a new builder who has built 2 pedals so far but I'm waiting for something I'm truly proud of for a build report.
I just finished soldering the PCB for the UniCab I just got and was interested in getting a MicroXLR board to add for the output to match the DSM OmniCabSim the pedal is cloned from. Does anyone knows how I would connect up the optional ground loop switch? I assume I just add a simple On/Off toggle switch and connect one port to ground and the other is left open?
I have experience with through hole soldering but have never worked with SMD components but I assume with some videos I can figure it out. If the PCB comes with a solder paste template I'm sure it would be much easier. Can any past purchasers can inform me on if it comes with that or not? Another thing I am contemplating is if this will fit into a 125B enclosure with another regular sized pedal PCB?
If anyone could share their experience using a Micro XLR board or answer some of these questions I would greatly appreciate it! Thanks in advance
Thanks for this post! I am also new on this forum and I have so little experience but I just want to get into this community and speak about things that I love!
