Emu Amp Sim
jcpst
I had this 99% done for months. I noticed there was room for these giant electros, which were the only ones I had at 220uf.
I always love when a pedal has a faceplate. My art skills are limited.
I’ve only tried this direct in. It sounds… fine? 🤷‍♂️ I wasn’t overly impressed by it. But I didn’t think it was bad either. I still need to see if it feels good for demos, which is the only time I don’t use an amp.
I have a hole for an XLR line out, but skipped implementing that for now.
I'm populating this guy now and plan on adding the microXLR as an output option as well... I see there are some pin headers listed in build doc... How exactly are those setup? I haven't mocked up enclosure yet so I'm not sure how the headers are used... I assume its for the switches hitting the right height for enclosure... Would like to know how you did it..
So conveniently I just finished a build the other day.
The trick is to to put the switches and pin headers on the little switch boards first, that way you can set the height and solder to the main board.
That makes perfect sense ... Thanks!
