p_wats
I'm back with the same Arachnid build. Starting a new thread, as I had marked the other switch popping thread solved...because it was!
Everything seemed perfectly fine after replacing C15 (the 1u MLCC in series with the output), but when I got it all back together and boxed up today, I noticed the LED was behaving strangely, and the circuit was popping.
I've once again hit that troubleshooting point of chasing gremlins to the point of making things worse, so I'm here again to let cooler heads prevail.
Where I'm at:
I've already replaced C15 again, just in case, but it didn't help (last time the pop was present regardless of the LED). I've also tried different LEDs.
I was sure it was all working fine, as I kept testing while re-boxing it up and looking for the LED, so I'm curious if something shorted as I crammed it all in the box, but hard to tell.
Knowing my previous C15 was leaky, is it worth replacing the others, just in case?
Where I'm at:
- Everything works fine in terms of sounds, controls, etc.
- There is a very slight pop without the LED, but nothing I would complain about
- The pop gets very loud with the LED installed
