Where to go next? Wanting to expand my knowledge
Itsmedant
I've been slowly learning how to build pedals by doing the clones here from PedalPCB, reading though a bunch of threads and trying to get my soldering and wiring skills down as good as possible. I've gotten 5 builds done and they've all worked perfectly right away, except one which I quickly realized I put a transistor in backwards!
I've been slowly teaching myself about each of the components and what they actually "do" to the sound/circuit but want to go deeper to fully understand pedals and gear like this. I probably would be totally lost in troubleshooting and tracking down issues on my own so I know I need to learn that skill alot more.
My question is: Where do I go from here? What resources should I start looking into? How do I push myself to get more efficient and learn more about pedal building?
My end goal: Design my own pedal circuits eventually.
Here are a few gut shots of the last 3 pedals I finished:
Almost finished Echovibe
Bellum Fuzz
Muroidea Distortion
DOWNLOAD LTSPICE
LTSPICE allows modelling of circuits and IMO is a great way to follow what ifs and have fun "playing" with electronics
Some Books and Websites
Small Signal Audio Design by Douglas Self is a great resource for familiarizing oneself with circuits.
If you like tedium, Art of Electronics is VERY informative.
https://www.electronics-tutorials.ws/ Everything here is useful for designing circuits.
https://www.allaboutcircuits.com/video-tutorials/ Another website
Khan Academy LOL.....
https://sound-au.com/articles/index.htm My personal favorite
Electrosmash website
GEO FX website
Study the schematics on here.
In terms of curriculum, there's obviously more to bite off than can be chewed at one time. Pace yourself.
I would reccommend learning topologies first such as
Buffer opamps
Non inverting opamp (think tubescreamers and Rats)
Inverting opamp (think summers and MFB filters)
common emitter amplifier (BJT, big muffs)
Common source amplifier (FET, every AIB on pedalpcb LOL)
Source follower (FET, buffer)
Emitter follower (BJT, buffer)
For filters:
Baxandalls and James
Fender style passive stacks
Bridged T and Twin T notches
Gyrator EQs GYRATORS are VERY USEFUL
Big muff stacks
Musical Clipping can be done many ways but most commonly:
Shunt diodes to "gnd"
Diodes in feedback loop of opamp (big difference depending on non inverting or inverting opamp)
JFET stages
Vacuum tube stages
Opamp clipping (🤮)
MOSFETs (diode connected mosfets too, think zen drive)
OTAs
Thanks for the advice!! I think I'll start going through the topologies and breadboard them all out one by one to see what they are doing on there.
I'm going to get LTSPICE too and start learning that.
You've added alot to my reading list!
The JHS youtube channel has a series called Short Circuit where they explain and breadboard a few of the classic basic circuits. He goes thru it slowly and in detail and it's easy to follow. He explains what different parts do and how they change the signal. I'd watch a few of those and get a breadboard for yourself so you can follow along.
Some useful back pocket theory/equations
Ohms law
Kirchoffs voltage and current laws
F_-3db = 1/(2*pi*r*c)
Impedance of capacitor goes to infinity as frequency decreases, goes to 0 as frequency increases
Inductor impedance is opposite of capacitor
Oh dang I never saw that playlist before! This will be fun!
I have the BB1 from Wampler so it’s quick and easy to plug into a breadboard now
it's what got me into building. I was ready to shell out 279 for a Skreddy lunar module and then came across that series where he builds a fuzz face really simply and for like a dollar and I was like :unsure:
If you don't have an oscilloscope think seriously about getting a decent one and learning to use it.
Troubleshooting, very simplified, is basically knowing what a circuit should do, and figuring out where and why its not. You are already working on the first part. Don't worry, as you breadboard and/or build you'll have ample opportunities to do the second part.
I would love a scope but I'm intimidated by the up front cost. Is there a "value" one out there that would have the features I'd need for a pedal but is less expensive? It's hard to justify as a "sometimes" tool.
I bought a cheap component tester that has a scope built in but not sure how great it is. From the advertised ranges of frequencies, it seems like it would work?
It depends on what you consider "value" cost wise. The o'scope I got, a FNIRSI, is around $200 now on Amazon and it's a pretty capable scope considering the price. I also build Tube Amps so it was easier for me to justify. When used in conjunction with an audio probe, especially when breadboarding, you can both see and hear what's going on with a circuit, as well as see and hear what a change in the circuit does.
It certainly will work frequency-wise. Human hearing goes up to ~20KHz, that scope up to 10MHz which = 10,000KHz. But that is a small screen so you will be limited on the details you will see compared to a larger screen. I will say it is better than nothing and if it works for YOU isn't that what really matters? The signal generator can be very useful. After looking at the specs closer, it looks to be a pretty capable scope considering the price. My biggest gripe about it would be screen size with my 60 year old eyes LOL.
My eyes have been able to see everything else on it so far. I used it to pick out some GT402 transistors for a fuzz I'm building for the first time the other day and it works pretty quickly!
I'll try to breadboard something out tonight and scope some stuff to see how it works
If you upgrade, get a high voltage one so you can do tubes if you want!
That';s the exact reason I wanted to upgrade! I have a Son of Yeti kit from Ceriatone that I've been slowly putting together, I'm at the step where I need to start wiring up the transformer so I'll need a decent meter for that! I think it needs to be Class III, and mine is just a class II.
