Byzantium Flanger not Flanging
Twinningses
Hi Folks,
Newish builder here and encountering an issue I haven't come across before: I've built the Byzantium Flanger but there's no effect.
Pedal bypass is working fine. When engaged, LED lights up, I get sound, but it's the exact same sound as when the effect is off. The knobs don't alter the sound at all, the trim pots don't alter the sound at all, etc.
I read another thread where people encountered this issue from using the wrong ICs and transistors, but I'm using all the ones to spec.
Interestingly, I don't even here any noise from the ICs that I would expect. Absolutely zero affected signal.
And... forgive my lack of low-profile caps here. I didn't have them for this build and so used what I had and just bent the caps so they still fit between the boards. I've been fairly meticulous to make sure their legs aren't touching things they shouldn't be, so I don't think that's what's causing my issue.
Any and all help very much appreciated.
Woof. This one can be an intimidating trouble shoot, but I would start by using the continuity function on your meter to verify that the board connections have continuity from one side to the other. Put one probe of the meter to the solder pad of one of the connectors and the other probe to the back side of its mating component on the other board.
Then, verify that each leg of each IC has continuity to its solder pad by touching one lead of the meter to the IC's leg and the other to the back side of the solder pad.
Check that the ground connection exists between both boards.
Some of your joints look cold and stressed especially on the 100v caps. the 100u on the top left of the pot board may be shorting it's legs when the boards are squeezed together.
Cheers I'll check those particular caps.
For cold joints, you know what my eye for them is not good ever since switching solders. When i was using leaded solder it was super obvious to me when there was a cold joint, but now that I'm using lead-free, I find every joint looks dull and cold.
Great thanks, will do connectivity checks across everything.
And yea this is a weird one. When I've head connectivity issues before, it's resulted in weak/no signal when engaged... not strong signal with no effect as is currently happening.
Hi Folks,
This one looks like there's not enough solder, other pads also look suspicious to me.
Might be an issue with your soldering technic.
Set the iron around 380 or 400°C, get the tip of the iron in contact with both the pad and the component's leg in order to simultaneously heat both of them for 2 or 3 seconds.
Then put some solder on the pad and remove the tip of the iron upward, along the component's leg, in order to form a nice dome.
You need the right amount of solder, not too much but enough to fill the pad.
If you do it wrong on a pad, use the desoldering pump to start again.
Take your time and give it time to cool down to avoid overheating your pads, and clean the iron's tip often on some piece of dry old sponge, slightly wet.
Ok thanks for the first set of advice:
I confirm that I have continuity through every leg of the board connections.
I confirm that I have continuity through each IC leg.
I confirm that the ground connection exists between both boards.
I have also reflowed all joints as per @jwin615 's recommendation, as well as checked every cap's legs to ensure they are not shorting.
One thing I did notice by happenstance is that both pins on the left board connector (circled in green) have connectivity to ground, where as neither pins on the right board connector (circled in red) have any connectivity to ground. The other three board connectors each have one connection to ground. I need to check the trace to see whether that makes sense but it's now 1am and I've got to call it!
The only other thing I could think of is that where one IC location calls for a "TL022" I have used a "TL022CP" but from what I read that shouldn't make a difference.
Any other advice would be super welcome, thanks in advance!
If you are sure about your soldering joints and checked with a continuity test all suspicious pads, you can try to narrow it down with an audioprobe.
You can find the signal path by drawing the shortest line from IN to OUT on the schematics.
Circuit powered and switched on, feed the circuit with a signal source connected to the IN jack.
Then probe the pads at various location on the signal path, following the schematics until you found a spot where the signal stops.
Check all connections with continuity tests, make some visual inspections, check components values and orientation, and reflow all pads related to that spot, according to schematics, until you restore the signal path.
You can also make some voltage readings on your transistors and ICs, to make sure they are getting the right voltages.
You can post your readings here if you have some doubts : pin1 = ?,
pin2 = ?, etc.
For transistors : E = ?, B = ?, etc.
EDIT: i cant find the schematics for the Byzantium, does someone have them ?
red : quick path that doesnt explore the full circuit, probing here and there will help you locate where the signal stops
and find suspicious aera.
green : quickpath to check if the signal is going in the BBD and Resonnance parts of the circuit, and comes back correctly.
You might try removing the top board from the bottom one and see if there is a change in sound. Leave them both wired to the footswitch, audio in/out, and power/ground, but separate them from each other (but add a ground wire to the solder pad next to the IN pad and run it to the other board)
@eh là bas ma thanks for this, I had a chance to audio probe some of this last night.
I annotated some of my findings on the below diagram. Green circle means strong audio signal, orange is weak, red is no signal.
First I checked the red line in your path: it was strong audio on the in and out points, which (unless I'm not understanding things) would mean that the signal is connected well through the entire line, even if I detect it as weak at certain other points?
I then checked the upper most green line you drew. While I couldn't detect audio at the FB_RecV1 point, I'm thinking it must be fine if I'm able to detect some sound at the C50k pot and the FB_Send1 point. It's just very, very quiet. Is that a correct interpretation?
I did have a moment to check IC1 and I didn't hear any signal at any point - just some random noise.
Any suggestions on next? Are my interpretations of "weak signal" ok?
Well, no. You need to probe at various points between In and Out, because there is a connection between C5 at the beginning of the circuit, and C19 at the end.
So having sound at the beginning and at the end of the circuit doesnt mean there aren't any issues in the middle of the signal path.
It just means your connections are good between In and C5, between C5 and C19, and between C19 and Out.
Not having sound at the input of the resonnance section (FB RECV1) is a problem.
It could mean the signal stops between your last checked connection with signal and FB RECV1.
If you have a signal at both ends of R37 but not on the next connector FB RECV1, then there is surely something wrong with that connection.
You will know that connector is fine once you can hear the signal at R42. It's also possible that your connector is misaligned and the pins arent reaching the connector on the daughterboard, it's quite hard to tell sometimes.
We need to connect perfectly both pcb together before soldering the connectors, to avoid any misalignement.
Maybe it would make your debugging much easier if you just add some extra wires on these connector pads to connect both pcb, and remove them once the effect works. It will at least put aside any doubts about these connectors until the circuit works.
To be able to probe parts like ICs, or check if they are getting the right voltage, you need to look at their pinout to know which leg does what.
You can google it, or use some website like musikding.de.
example : TL22
So as you can see, depending on how the IC is implemented in a circuit, you may have some signal on all pins except pin4 (ground) and pin8 (V+).
Looking at the Byzantium schematics, signal enters through pins 5, 6, 2 and 3 and gets out from pin1.
So if you have no signal at all at IC1, you need to find where the signal stops before reaching this IC with your probe, following the schematics.
IC1 is part of the BBD section, so first thing is to check if your signal reach C6, near the input of the BBD section.
If it does, keep following the signal until you find where it stops before reaching IC1.
If it doesnt, find where it stops between your last checked connection IC2 pin7 and C6.
Once you find a spot where the signal stops : visual inspection, rework on all pads connected to that spot, use your desoldering pump and start over if needed, continuity test between the parts's legs, and not just the soldering pads, to make sure the connection is good, etc.
Soldering pads are connected to each other with the pcb traces, testing continuity directly on components legs is what matters the most to check the connection.
You can also desolder a resistor's leg and check its value with your multimeter if you think there might be a mistake somewhere.
You cant really check parts like resistors if they are still soldered to the board and connected to other parts, the other connected parts might impair the readings, you need at least one leg out.
Also make sure all trimmers and pots are set at half rotation during your debugging process, so they dont block the signal by being turned off.
Finally, if you really cant get a connection to work as shown on the schematics, the signal stops and nothing can restore the signal path, it could mean there's a problem with the trace or the soldering pad on the pcb.
In that case you can use a piece of wire to connect both parts, as shown on the schematics, in order to fix the signal path.
