PPCB Deep End
Mentaltossflycoon
5.00 star(s)
I really like the stock superfuzz that I built on a Moonn pcb but it's never seen much action. While it's a fun time on bass, especially considering the era it comes from, it doesn't actually rank that high on my own shelf of bass specific doom. Getting my mitts on a bassified version was most welcome even though I usually do not enjoy the clean blenders.
My first impression was positive. It's a massive beefy fuzz though I felt like some clean was present at all times. I had seen @johnk_10 mention that he felt the same so I stole his mod using a 500k trimpot instead of his suggested value. I ended up preferring it just shy of maxed out. Now I don't hear any clean at "zero blend." Happy days.
Comparing toans with the stock built superfuzz, the Deep End actually has slightly less bass with out the clean signal. They definitely sound similar while being different enough to warrant building both. The gain control on the Deep End is more subtle than stock. The stock superfuzz changes a lot more before wimping out though I'm not all that interested in the lower gain sounds of either pedal.
Very nice! Thanks for mentioning @johnk_10's mod here -- otherwise I might not have found that. What about the stock trimmer in the center of the board? Did you happen to find instructions for adjusting it? Based on the schematic, it seems to affect the interplay of Q4 and Q5. Is this to adjust for Q4 and Q5 of differing hfe (are they ideally matched)?
That's what I had assumed, I never saw anyone mention anything other than the expected transistor matching for superfuzz type circuits. I matched Q4 and Q5 and it fired up right away so I didn't really mess with that trim pot.
So I did a deep dive and hit my head on the empty pool-floor beneath the high-diving board,
ie I couldn't find hide nor hair of John's mod whether searching here or TalkBass or BassChatUK...
Apparently my search Gong-Fu has become more "search-me 🤷‍♂️ Gone-Fooey".
Looking at your gutshot, it looks like you've replaced R30 with a Trimmit — and you say you used 500k for that!?
What was Mr Kallas' suggested value, did you go bigger or smaller on the trimmer? Would 250k suffice?
Yes, I think he used a resistor greater than 200k which is why I went with a 500k trimmer. I would guess that mine is set somewhere around 300k - 350k but i don't know how much benefit I'm getting from that increase. I just stopped messing with it when I was happy.
