Kliche Mini Special Edition Test
Jonathan1986
I'm a complete novice in understanding schematics. Can a whiz out there let me know how to wire this up to my PedalPCB test station? The board does not label which wire holes on the footswitch are ground, in, out, switch, etc.
No worries. By the way, which PPCB test station are you using? I'm guessing it's the Auditorium Test Platform - just use the daughterboard with your build, ignore the Bypass section of the test rig and use the stompswitch on the daughterboard for testing. Given study and time, you got this. ;)
Sorry, the "duh" was self-deprecating to myself, not attitude to you lol
In fairness the build docs don't show actual wires. I'm pretty new to PCBs myself having built mostly on Veroboard prior. I have to admit I wondered about the 3PDT PCB and followed a few traces before I said "Duh! it just jumps over directly!!" Don't feel too bad!
Yes, the Auditorium Test Platform, it's great for testing, helps so much with troubleshooting if you know your board is fine you can isolate to the wiring or footswitch to correct the issue.
Actually, not sure this makes sense. How will I know where to run the in and out signal from the board with those are taken up by the ribbon cable on the footswitch? I won't be able to use the test platform at all if it's wired up to the footswitch??
search here for kliche true bypass and that's how it would wire to the auditorium like a traditional board... Hence why the kliche comes with a footswitch daughterboard.... it's because of the buffered bypass and that daughterboard is specific to that build... There's a few pedalpcb projects similar to this..
Use the IN/OUT at the top of the board, these won't be attached to anything else.
With the footswitch attached at the bottom you'll be able to test the buffered and active modes.
