Yep, I saw that 47u and figured it was involved. Good to know that the 1u does it too, sounds like it must be normal!I believe this is because one pole of the switch is sending signal through a moderately sized electrolytic cap
That's the oneCan you link to that Build Report? I’m not finding it…
Hopefully people who have built this can chime in, I’m curious too.
That’s what I supposed but wanted to confirm.I believe this is because one pole of the switch is sending signal through a moderately sized electrolytic cap
Since it's normally open ended (1), it's not building charge, so that "pop" and signal delay when it's toggled (3) is the signal passing through, and the capacitor needs to build up its capacitance. Mode does the same thing with its 1µ bipolar caps. I think this is normal operation.
