stinkfeet
Hi,
I have a muzzle I built a little while ago that I'm just getting to test now, and it's definitely not working correctly. I've reflowed all the solder joints like 3 times to make sure, and I've soldered everything that I used these on. Right now, it's super fuzzed out and low volume; the light doesn't change colors while playing, it only changes based on where the threshold is set. The volume increases as I turn down the threshold. In the demo I did, I started with it bypassed, and then I clicked it on with the threshold maxed and turned it down as I went, and at the end I went back to bypassed.
Any ideas on what's happening? A dead IC or transistor?
