PedalPCB Nobleman Overdrive/Nobels ODR-1 1590b
OD is Glorious
5.00 star(s)
I am probably keeping this one - the last two I built went to friends. Fun project, and you get a great sounding overdrive that can provide clean boost or saturation. I used an A25k for the presence knob because I was all out of B25k. Maybe do not do that because all of the presence is at the end of the turn. Otherwise this is sensational.
I used all of the correct components with the exception of the B25k potentiometer (I used A). The Led is a red 3mm water clear in a clear Freznel. I used a 5K6 resistor for the LED. The footswitch is a full size feather click, the jacks are low profile enclosed and the D.C. jack is Lumberg. I socketed the 1N4148 diodes. I used the Davies 1611 knobs. The enclosure is a Tyda pastel green poweder coated 1590b with a waterslide decal and 2k clear.
Everything fits in here if you use the low profile electrolytic caps... PPCB has them and so does Synth Cube. Most of the parts are common, but I listed some uncommon components below.
Notes
  1. You need a 2N5457 transistor
  2. A 2N7 film capacitor
  3. Two 8N2 film capacitors
  4. A 120p ceramic capacitor
  5. A 560p ceramic capacitor
Great looking build!
I recently build an ODR-1, and I'm really liking it. I've built them before, but always felt the flat(ish) frequency response and/or bass-forward EQ made me disappear in a band mix. But hopefully with the bass cut and actually understanding the spectrum knob, I can make it work this time around. So far so good with the playing I've been doing with my neighbors.
If you have some on hand, try some RC4580 opamps in place of the RC4558. In my build, I originally used good ol' 4558, but then I replaced them with 4580. It could well be expectation bias, but I do think the 4580s make it sound better. At least on paper, the 4580 has much better specs.
What made me take another look at the 4580 was Rod Elliott's "Opamp Selection" article. Which itself is ironic, because he's essentially arguing that in many applications - definitely in guitar effect pedals - any halfway decent modern(ish) opamp will perform as expected.
Either way, if you have some on hand, and you used sockets, it's a fun and easy experiment.
Thanks for checking out the build and for the tip! Turns out I have some JRC4580D from Stompbox.
The PCB that was used in this build report is the PedalPCB Nobleman. It's out of stock right now, but you can sign up to be notified when it's back in stock. Personally, I feel that PedalPCB's prices are more than fair; and they are a steal when you factor in the regular sales.
Sorry—I’m actually new here, and I’m a bit desperate to get this pedal built. My goal isn’t to get the original Gerber files for the official board, but rather to connect with someone who might have built one themselves. Unfortunately, even though the boards themselves are inexpensive, the total cost for shipping and taxes to Brazil ends up being quite high—practically the price of a ready-to-use Nobels ODR-1. I’d really like to build it myself, partly to repurpose the enclosure of a pedal I’m quite fond of, even though I don’t particularly care for its tone. It would be great to just buy a pre-made board (which would be much less work), but the shipping and taxes make that unfeasible.
If anyone could help me out, I’d really appreciate it. I’m looking for a layout that fits a 1590B enclosure.
I may have an extra Nobels board I can. pop in the mail. I can check later tonight
But do you know if it would be possible to ship to Brazil using an economical shipping option? Taxes are charged on both the value of the product and the shipping cost.
I have no extras
The board is $10.20 and PedalPCB ships worldwide, offering international shipping options through postal services. I imagine you will have to order through the website when the next boards come in. When I asked PPCB they said some boards were coming in next week.
Do you have low-cost PCB fabrication services in Brazil? If not, won't you run into the same problem with having the custom PCB imported?
Notes
is this essentially the fabled "tubescreamer without the crappy mid hump"?
shouldn't a 2" wide board fit inside a 1590b?
I just fit a transcendance boost board in a 1590b2, and that board is 1.95" wide.. the nobleman is only .05" wider..
there's still a lot of room on the sides
probably ~.20"
pic related to give you a scale comparison
edit- if you are concerned about the height, a 1590b2 is almost as tall as a 125b, and a 1590bs is a little taller..
