Harry Klippton
Not Interested
I have encountered what I think is a thermistor and I have some questions. The component in question can be seen below. It's red and labeled RT1:
It appears on the schematic here:
And since the circuit spans several pages of the schematic, I've redrawn it here:
I'm assuming that its purpose in this circuit is for some kind of current limiting to protect the motor rather than thermal protection or something. The circuit is not behaving as expected. How would I know if it was out of spec? How can I test it? Is this a thermistor?
Searches for SDT-09 don't return any results for any components that look like this, nor do any searches for the part number listed in the service manual. I measured it in circuit and got 120 ohm. I don't think this component is actually causing a problem but I'm curious about it, not having encountered it before.
The tape transport runs a bit slow. R47, R48, and R1 are in spec. I also disassembled the motor and it is not physically damaged. I replaced the internal motor control chip to no change. I also swapped in an entirely different motor to no change. I disassembled the transport to look for sources of physical resistance to which I found none, and lubricated all moving parts for good measure. The motor is receiving 12 volts as specified in the schematic. The pulley is not slipping on the motor shaft and there is a new capstan belt
To recap, is RT1 a thermistor? How can I test that it's working properly? What's it doing there?
