Aleph Null Cremulator Troubleshooting Low Frequency Oscillation
Got it built up, everything seemed fine at first but when I take the fuzz knob to the last 1/4 or so of its travel I get a strong low frequency oscillation. Worked with @Aleph Null via DM and tried swapping several components to no avail, so it was suggested to come here and seek the wisdom of the forum sages...
I'm hoping that getting more eyes on this will help us find the issue. Here's the schematic for reference:
Things we've tried already (in no particular order):
  • Increase C4. Pitch changes, but still sounds like a foghorn.
  • Replace the electrolytics. No change.
  • Increase R3 and/or R5 to reduce gain. No oscilation when guitar is disconnected. Oscilation comes back with the guitar is plugged in.
I don't see any obvious solder bridges, so that's good. It's probably still worthwhile to reflow the joints just in case. Also, do you have an audio probe?
It's probably also worthwhile to check the voltages at the legs of each transistor. Be sure to install stock values for R3 and R5 before checking. Here are the voltages on my working copy:
Q1Q2Q3
Pin 11.704.074.46
Pin 21.661.944.06
Pin 30.250.021.95
(I powered the pedal using a One Spot with 9.4V output.)
That’s only superficial as it was lightly marred during component replacement; the issue was present before the capacitor was swapped and any surface damage done.
My bad, I should have specified that it looks like the solder connection for the ground plane is bad. Probably not the source of the issue, but less power filtering could possibly exacerbate the issue
Q1Q2Q3
Pin 11.704.074.46
Pin 21.661.944.06
Pin 30.250.021.95
Q1
P1 -2.88 P2 2.85 P3 -.64
Q2
P3 -4.23 P2 -2.02 P3 -.05
Q3
P1 -4.53 P2 -4.21 P3 -2.03
Q1 seems significantly higher on mine while the rest look to be within range.
Audio probe was misplaced when I moved and as of yet undiscovered in the boxes.
Q1
Q2
Q3
What does R1 measure at? Do you have a free BS170 you could swap Q1 out for?
I just measured a dozen more BS170 with the same bias network as Q1 to try and get a sense of the variance. Your Q1 is measuring about 0.5V higher at every pin. I'm not saying it's definitely that transistor, but I think it's suspicious.
