Idroj
Hi! And this is the 3rd and for now, last faulty pedal I build. A RAT that, now that I remember, I got from Tayda, pcb included. I built it, and similar to the Blue Breaker, I was able to enjoy it for a few seconds and then nothing.. I took it out of the enclosure, used this system that this youtube explained to narrow down if the problem is in the pcb board or the wiring, and it only worked for a moment, sounded amazing, but just for those few seconds. Now that I fixed 2 pedals this week with your all your help, and learning lots of things, I guess that a good place to start would be a good cleaning, right? I'll also have to try to unplug some pads and re-wire the 3PDT switch board...
Should I reflow anything else or just start the IPA toothbrush cleaning and put it all back together?
If I get to fix this one, after having fixed the other 2, this will be a HUGE VICTORY! Thanks everyone for taking the time to help out!
		 I'm not a huge believer in the "MOJO" parts camp, but I have found that certain components work better in certain circuits. In this case the LM308N does sound better. And no matter what, I would change out the TL071 in this circuit, not a huge fan of the TL chips, if you push them to hard they break up.
