BeeSharp
Hey
Working on a Kliche' for a friend and the bypass sounds right, but the volume drops way way down when engaged. I thought I might have melted the battery red lead when I soldered the pcb's hot wire to the jack. The missing parts are mounted underneath to fit them better. Just digging in to this...
Thanks
PS. I did do a quick voltage check and the 9V power coming from the wall wart is that same as what the pcb is seeing. When I engage the (older) battery I only see around 7.5V and it is testing around 9.20V.
Thanks
