Megatron TMK2601
Willybomb
This is my 3x Octagon build, using 3 custom eeproms to have a board each dedicated to reverb, delays, and effects. The reverb and effect boards have switches to access the onboard FV-1 patches.
Bit of fun, I've since sold it. Possibly too many options for me...
Looks awesome, what do the bank buttons do? Thanks for sharing, pretty amazing pedal, you can definitely explore effects with that. :)
Where do you get those DPDT 'bank' switches? Those look like they'd be a great alternative to a toggle switch if space / clearances were limited.
They're these one from Jaycar (an Australian electronics store).
They work in this case because they're not particularly high so they don't foul anything when you step on a footswitch, but they are quite large in reality, think arcade button size (maybe a touch smaller).
Thanks for that! The required hole size appears similar to the 3PDT, correct?
very neat layout on the wiring. what did you do to wire in the bank switches to tap the default programs in the FV1?
You send pin 13 of the FV-1 to ground, iirc. There's a 10k at the base of the eeprom that I socketed, ran to the switch, and back again. The switch goes to ground, or to the 10k back to the eeprom.
It's 18mm, so a bit bigger I think. Here's the unfinished box.
