ShatteredOne13
Hey all, just build my first pedals and the second one I put together was the Tyrian Distortion. When I play through it, I have to turn my amp up quite a bit more then I really should have to.. The tone sounds great, I get beautiful distortion out of it, and have no complaints on that end, which is what confuses me. I’m not sure what exactly would cause this sort of result when building. All values were double checked with volt meter before install, and after soldering in place just to be sure I didn’t mix anything up. I mean, the way I do my assembly is pretty fool proof as well, but the perfectionist in me still needs to double check things. Any help or suggestions on what might be causing this issue would be awesome. My other pedal pushes out at the same volume as it should, but this one when engaged is quieter then my clean channel when pedal is on bypass when it should be quite a bit louder with the volume pinned. If I need to pull the pedal apart to show the solder joints I can, but I’m pretty positive those are fine with my experience in soldering and how anal I am about it anyways
 I posted pics with this, but if more are needed just let me know please and I’ll pull it apart and get whatever photos/angles are needed !! Thank you all ahead of time for your help, couldn’t ask for a better forum then what I’ve seen from this one, it’s amazing how good of a group you guys have built here !! Thanks !!
			 So I’m guessing beyond that, voltages were fine ??
