Did a quick search and didn’t see a similar thread, apologies if I missed it, but I was putting together a parts order and was thinking I’d share the offboard parts that I use and ways they make my builds easier to build and/or more reliable.
If anyone has other suggestions we could keep the thread going? Lots of these parts have been referenced elsewhere in the forum, maybe collecting them all in one spot might not be so bad.
From Mouser:
https://www.mouser.com/ProductDetail/593-2000C
SMB_200_CTP LED lens - a match for the "3mm LED Lens Type #1" that PPCB used to sell, fits perfectly in the 11/64" hole on Tayda pre-drilled enclosures, and I like the fresnel lens look over a round bezel, personally.
https://www.mouser.com/ProductDetail/538-25001-0802
Molex 25001-0802 jumper cable - it's 2" long pre-stripped pieces of 8-conductor jumper cable, I cut these in half and use them for PPCB 3PDT breakout boards, it's almost life-changingly convenient.
https://www.mouser.com/ProductDetail/575-91743103
Mill-Max TO-5 transistor socket - these are basically the go-to transistor socket recommendation, and I've not found a better price on them than at Mouser
From StompBoxParts:
https://stompboxparts.com/jacks/1-4-stereo-enclosed-jack-lock-teeth-panel-mount/
1/4" Stereo Jack with Locking Teeth - these jacks have teeth that stab into the wall of the enclosure when you tighten them, so they'll never come loose, and you don't have to sand down the paint around the jack to get that ground connection. I've switched to using these jacks pretty much exclusively for anything that doesn't need a switched jack.
https://stompboxparts.com/switches/3pdt-footswitch-pro-latching/
SBP 3PDT Footswitch Pro - these 3PDTs have a softer click than most three-dollar switches, take heat like a champ, fit PPCB breakout boards perfectly, and are a buck cheaper than the Gorva Pro Switch (that, in my experience, didn't fit the PPCB breakout board and wasn't noticeably softer to click)
https://stompboxparts.com/switches/metal-footswitch-washer-10-pack/
Metal Footswitch washer - I prefer these over the white nylon washers.
https://stompboxparts.com/semiconductors/v3207d-and-v3102d-bbd-clock-sockets-pack/
Fancy ICs - Also, as of right now, StompBoxParts seems to have the best prices on Belton Bricks ($13 for the BTDR-2H, $15 for the BTDR-3H), Spin FV-1s ($14), and V3207/V3102 BBD sets for the Ceasar Chorus ($2.75 for the set)
From Tayda:
https://www.taydaelectronics.com/hardware/enclosures/drilled-enclosures-for-pedalpcb.html
I mean, the pre-drilled 125Bs *gotta* be on this list, right? Biggest time-saver in the whole process for me (although I do still have to drill one hole bigger - the hole for the DC jack, because of the next step below).
https://www.taydaelectronics.com/dc-power-jack-2-1mm-enclosed-frame-with-switch-external.html
2.1mm external switched DC jack - I like the external jack because I don't have to desolder the jack to remove the PCB from the enclosure, and I've had lots of issues with the mini jacks (they're stiff, I've had multiple fail, I've melted more than a few trying to do reworks). I *have* had an issue with the nuts these jacks come with stripping and not properly tightening, so I do have a bag of "Outie" DC Jack Nuts from SBP when this happens.
Also, not an offboard component recommendation, but I eventually stopped borrowing work’s automatic wire stripper and got one of these off of Amazon which seems to be of comparable quality. I *hate* stripping wire because I am only human and can’t do it nearly as quickly or repeatably-accurate as an actual tool can
From Mouser:
From StompBoxParts:
From Tayda:
