Something about MXR Distortion 2
NickC
i was reading this article about MXR Distortion 2
https://catalinbread.com/blogs/kulas-cabinet/mxr-distortion-ii ,
i have a "Made by Mike" clone that doesn't sound bad but honestly I've never listened to an original one, and from what I see in the pictures the circuits don't look the same.
I read that Mike has modified the circuit according to his tastes, i don't know if anyone owns an original one and could tell me if they actually sound the same.
a 100% clone would be nice.
I built a clone a few years ago and tried both the stock and Made by Mike mods.
There's definitely an audible difference.
by chance I found this schematic online, so I just need to change those 6 components to get closer to the stock sound? @PedalPCB
I used that layout some years back, and tried both stock, and Mike's components. It's been a while since I played through it, but I seem to remember Mike thought it was far too bassy. I'm fine with that, so I stayed with the stock setting. I also think the real ones ran at higher than 9v.
Mike also sold them in a dual enclosure with an op amp Muff for the Pumpkins sound.
Revisiting my old build, I see Res#1 on row B (ground) , where all schematics I've seen say it should go to Vref , which is row C. The layout I used looks just like the one posted by NickC, except the filter lugs are reversed.
The only clone PCB's I know of are BYOC and Lectric FX
The original could be pretty bottomy but I think that contributed to the massive Smashing Pumpkins sound. The lack of volume was a common complaint on the originals. Even the clones I've built had a very limited range. LectricFX did a really nice board that helped but still hard to get past unity volume. I've never played a Mike version.
Yeah, I had an original and it’s a unique sound to be sure. Verrrrry speaker dependent.
Capable of some nice lower gain tones on its own, but stacks with a muff like nobody’s business.
i had the made by mike, i sold it because it only had one decent setting, otherwise it was weak. As for the pumpkins i think their gear information is full of half truths, i don't think the mxr dist 2 was used on all solos but only on a couple at most, like the use of mutron biphase.
Yeah I was quite content to sell mine to a collector and turn the proceeds into like 4 home built pedal projects.
