Working on a new build... having issues. Made an audio probe, and trying for the first time. I have audio going into Pin 1, but nothing out of Pin 28... I also have audio into Pin 2 and Out Pin 27. Im finding any components directly downstream from Pin28 with no signal. Components around IC3 are a little wonky too, but Im chalking that up to its location after the FV-1 chip. Also, not getting any signal out of pin 20, which looks like its attached to the tip and switch. Not sure what to do next. Any help would be appreciated. When I probe pin 27, I get audio and some of the pots on the pedal function. Im working on the Leprechaun. Does this pedal use both pins 27 and 28 for output? Schematic I was given looks like it does, any friendly advice would be appreciated. Trying to avoid having to resolder a replacment FV1....Im lost here guys, I could use some help.
Thanks
Thanks
