OK, here it is. I was able to find a configuration with no compromises (no need to change R2a & R2b). In Normal mode, everything is interconnected exactly like the stock version. In Series Mode, the Input connects to Ch A input, Ch A output feed Ch B input and Ch B output connects to the Output. No changed to the the ON/OFF switch wiring. The LED on the Series/Normal switch lights up in Series Mode. If you don't need an LED on the Series/Normal switch, then you can use a 3PDT switch and wire the center pin on the A/B switch to GND. Someone should check this to make sure I didn't make any wiring errors.
