SOLVED Caesar Chorus click with Rate
pryonisys
Hello all, I put together the Caesar Chorus and it sounds great when engaged, but I'm having a problem when the effect is bypassed. The bypassed signal is clicking with the rate of the effect (each time the LED fully lights or dims I get a click). This does not happen when the effect is engaged, only when it's bypassed.
Has anyone else experienced this? Any thoughts for solutions?
What kind of bypass are you running?
If it's 3PDT, you could try grounding the PCB's output in bypass mode.
More common to ground the input in bypass mode, from what I gather, but in this case it makes more sense to me to ground the board's output when bypassed.
