Hello, this is the first pedalpcb board I build. I was having a lot of troubles with the wiring but this is now where I can't seem to advance further
bypass is working.
when on, led turns on (picture does not show LED because It is not soldered to the board)
when on, with volume at zero, there is no sound. as I increase the volume, there is only noise (no signal though).
Both Tone and Fuzz knobs affects the noise, so it seems there is no issue in that part of the signal path.
Actions taken - melted every solder to make sure no dry solder, checked components (hopefully didnt miss anything).
substitutions to the original design:
1N270 in place of CG92H
1N4732 in place of 4V7
GT402BC in place of OC140
attached are some pictures, maybe someone can help and I will feel horrible if it is something ridiculous.
thank you all.
bypass is working.
thank you all.
