I don't know if anyone else went ahead and built their VIIB even before build docs are posted...well I couldn't wait! Without biasing instructions I'm just guessing but I've got it in a place where distortion is minimzed and the vibrato happens sometimes (see below). Running at 9V, it draws 10-12mA. I'm testing with Depth turned up pretty high and Rise Time turned down. Here are a few initial issues..
- I get sound in bypass, then volume jumps up 5-6db when pedal is "On"
- LED does not light at all. Using what I thought was the recommended red/blue one from Small Bear, still works when testing with my multimeter
- only time I hear the vibrato effect is if I turn the Rate knob up from full CCW, then the vibe comes in briefly (and sounds great!) but quickly flattens to a regular signal
Only substitution is a 500k trim instead of 470k. BBD is a Panasonic MN3207 from Banzai Music (text is very faded). Clock is an MN3102 I stole from a previous build so I know it works. I'm using the posted footswitch and the relay bypass system does seem to work, in that it will latch on/off with quick taps, but is momentary with longer hold times. I'm not sure how to switch between True Bypass and Classic modes.
No expectation of comprehensive help at this early stage of the board's availability but if anyone wants to chime in that'd be great.
