cgmason1986
I built a clone from aionFX Muramasa board, but I get a slight pop when I engage the boost. Does this need some kind of pull-down resistor somewhere? Here are the build docs with schematic:
Thank you!
Thank you!
Thank you - would this be the top row or bottom row or the switch? (Up position engages the additional boost)It might help to add 1M bleed resistors from A1 to ground and B1 to ground.
| DPDT LUG# | SCHEMATIC # |
| 1 | A3 (NC) |
| 2 | A2 |
| 3 (add 1M to GND) | A1 |
| 4 | B3 (NC) |
| 5 | B2 |
| 6 (add 1M to GND) | B1 |
Exactly what I was looking for - thanks!Lug numbering of DPDT:
1 4
2 5
3 6
UP position of toggle means Pole 1's lugs 2&3 are connected as is Pole 2's lugs 5&6.
The 1M resistors would go between 3&GND and 6&GND:
DPDT LUG# SCHEMATIC # 1 A3 (NC) 2 A2 3 (add 1M to GND) A1 4 B3 (NC) 5 B2 6 (add 1M to GND) B1
Just an update - I added the resistors, and it's working perfectly. Thanks for your help!Lug numbering of DPDT:
1 4
2 5
3 6
Thank you! Couldn't be happier with it, check out the front! Behold the "Kelly Kate Anna" (get it?)Excellent! Love your implementation as well, nice and classy.![]()
Cool Build, good play on words!Thank you! Couldn't be happier with it, check out the front! Behold the "Kelly Kate Anna" (get it?)
Thanks - it's fake, I kill all my real plants.+1 tasteful houseplant
