Possible to bend the tabs on pots holding the PCB?
Preverb
I've run into a bit of a problem with the Tayda drill tool for the Clandestine preamp. I am sure it will get solved but it got me thinking if I could have gotten away with the pre-drilled 3 hole 125b. The holes are off by a few mm. I am not sure if you can bend the potentiometer tabs to accommodate a few mm? Has anyone done this in the past?
You could always cut the legs off and run wires to. Bending the legs might be possible but you have to make sure the shafts are still straight
Instead of that, consider drilling the holes out a bit bigger and using larger diameter washers on the pot shafts to cover the bigger offset holes.
I hadn't thought of that. I dread the idea of marking up nicely UV painted enclosures but I could probably hand drill them out from the underside. There are also some PCB projects from other sites I want to try. They are also off by just a few mm.
Won't the PCB be flopping around on the wires internally then? The tags from the pots normally hold the pcb in place right? Or do people just put in some foam or secure the PBC some other way?
Yes and no. Depends on how you do it and how much room is left in the enclosure. I've done it a few times to make my own knob layout and I like the results
It's certainly not the ideal solution, but I've done it... I've put a PCB with 1.3" spaced pots in an enclosure drilled for 1.6" spacing by bending the pots outwards slightly. As long as you're careful and put the stress on the lugs and not the PCB/solder joints you can do it.
What happened with the Tayda drill template? The coordinates appear to be correct.
Nevermind, I remember, this was the situation where the template tool throws an error for no good reason.
The 3-knob template is the same spacing as the Clandestine Preamp, but you'll have that unneeded center hole.
This is good advice too.
At the end of the day, you just need to try some stuff and build some pedals to find out what works for you. Have you completed any builds yet @Preverb ?
It's quite easy to break this brown piece of laminate that holds potentiometer legs. So I would not recommend bending legs. Just use different type of the potentiometer (solder lugs, short straight legs) plus resistor cut off legs. If you do not want to buy any extra pots - just cut off the legs close to the laminate and use resistor cut off legs.
It's not quite as suitable for the Clandestine Preamp since the only other anchor point is the toggle switch, but in some cases you can mount whichever hardware will fit the drill pattern, then offboard wire the remaining hardware. This works best when a pot is in the center of the PCB.
Don't know. I had an initial response from Hugo. I sent him the screen shot earlier today but will likely have to wait till tomorrow now.
Still waiting on the PCBs to come over to Australia. And my Tayda order has been delayed due to some error with the drill tool. That's what prompted this thread. I suspect the pcbs will get here pretty soon though. Hopefully Hugo will figure out why the error is occurring when I try to assign the template to the job. I've built a few amps in the past so hopefully the pedals will go smoothly.
Try this template and see if it will work:
Thanks for that. Unfortunately still the same result. I wondered if submitting the drill request by itself without the UV printing would work but no luck with that either.
Ahh well, was worth a shot. I thought that maybe since it was derived from the 3-knob template (with one hole removed) that it was still expecting the extra set of coordinates so I recreated the template from scratch... no such luck.
Thanks. Appreciate the effort! Hopefully it will get sorted out soon. Otherwise, I might try to just make the 3 hole 125b work. I guess with this one, the switch will have even shorter tabs so all of the tab bending will have to be at the one pot.
Hope all your stuff gets there soon and you can get this thing on the move 🕺
I bend pot tabs all the time and a lot farther than a few mm. It's not a problem. Best way is to put the pots in the enclosure first then mount the PCB and solder it in. You can take it out from there if you need to test it. You don't want to bend the pots once they are soldered in because it can put stress on the joints.
All is good now. Hugo fixed the error on his side. There is a pcb from another site that I was thinking of for bending the tabs. But now that the drill tool seems to be up and running again, maybe I can create a template for it. Only problem is his stuff is in imperial. When is the US going to adapt metric? Imperial seems so archaic...
Speaking of that, ever seen how a King of Tone is assembled?
Like I said, bend slowly... those take like three years to bend.
kotbuffer-1-jpg.392224
I always thought the waiting list was for that the build take so long to populate.
So all this time is spent trying to get the Pots to line up with the holes so you can put the lid on!!!
