Preverb
I've run into a bit of a problem with the Tayda drill tool for the Clandestine preamp. I am sure it will get solved but it got me thinking if I could have gotten away with the pre-drilled 3 hole 125b. The holes are off by a few mm. I am not sure if you can bend the potentiometer tabs to accommodate a few mm? Has anyone done this in the past?
