I have a fun issue with my Pitch Witch build, where plugging in a cable to either input or output causes the whole circuit to cut out (based on the modulation LED turning off... and not back on). On investigation it seems like it also happens when the sockets are held at a particular angle against their holes in the case. It seems to me like a short with probably a very obvious cause but I haven't been able to find an answer so far, can anyone help to put me on the right track?
I've checked through the soldering and can't find any of the usual suspects. The case is a Tayda painted pre-drilled one.
