knobToucher
I posted on the first revision of the forum that I was having trouble generating feedback with the momentary FS...
I recently got a new soldering iron and decided to reflow all the connections just in case shoddy soldering might be the culprit. Once I'd done that I connected it all up but was experiencing the same problem. I held the FS down and started touching the connections on the back of the board near where the momentary is wired up (so basically all the transistors) and got some weird modulates pitch noises. After I did that the FS miraculously started working!!
So I just wanted to put this out there and ask if maybe this is a grounding issue or something? The PCB is not in an enclosure, all the inputs/outputs are wired to their spots on the board. However, I'm getting power by connecting the 9V positive and ground to a speaker wire terminal that is connected to a regular plastic DC socket. Do you think if I box her up my issues might disappear?
