I bought a Marshall 2203 reissue from reverb a little while ago and it arrived with a broken FX loop(which is kinda the whole point of the reissue for me.) So I took it to an amp tech a day or two after I got it and didn't get it back until nearly two weeks later. Once I finally had it back and spent some time playing it, I realized I was getting really bad hum/buzz using the high input. Anyway, I didn't want to go back to a tech, and here I am building and starting to design my own pedals so I thought this was a good opportunity to learn a little more about tube amps. After much blood, sweat, and tears, and a little help from some nice folks on another forum and some guidance from the tech who fixed the loop, I finally ended up tracking down the source of the hum which was a blown "hum balance" trimmer. Kind of ironic eh? I did run into one condescending guy on this other forum that told me I needed to go to college for 5 years before working on amp, so obviously I was even more driven to do this myself and stick it to him. It was a very interesting learning experience and I had to do quite a bit of research on safety precautions before I felt comfortable poking around in there. Being careless inside a 9v pedal ain't gonna kill you but a 100w tube amp on the other hand...
Just curious if anyone else on here dabbles in tube amp repair/building/modification. There is definitely a crossover with the pedal building, but I've come to learn high voltage work is a different animal. Once I started to understand the basics of how a tube actually works it became much clearer but I still have a lot to learn. I definitely felt like I was learning in reverse because in my head I'm comparing a transistor's functionality to a tube when obviously the tube came first. Heaters, plates, transformers, yada-yada, lots of stuff that you don't come across building pedals.
