Paragon mini
It looks very fine!
I'm looking this project right now and I have some doubts about the diodes. Common 1N4148 and 1N914 will sounds ok. But it's almost impossible to found the original ones. But even some good alternative diodes.
What diodes in your built? Some advice about them?
Thanks!
It looks very fine!
Thanks!
DM me, I have plenty of diode options for the Paragon, be happy to send you a couple.
I've built a bunch of variations of the Paragon/KOT pedals and have most of them socketed diodes. My favorite and best sounding to me is the BA282 but I also have variants with the MA858 and BAS33-TAP. All of which are EOL but there are still plenty of BAS33-TAP to be had cheap.
I got a bunch from Mouser.
Do you hear a real difference between diodes? I have built a couple KOTs and have the diodes socketed to try different options. I had an original years ago with the magic unicorn tear diodes. I learned I don't like it at 18v, it's gotta be 9v for me. But I heard no real difference between any diodes, although I don't have Eric Johnson ears. The ones I liked the most were 4148s and 4001. No one uses the hard clippers, let's be honest lol. I actually preferred the lower clipping threshold in the soft clippers because even with the high gain option there isn't much gain to be had still. @swelchy solid build, looks good.
I do hear a difference but specifically with the BA282's. Something about them just sound "thicker" and "girthier". Not so much between the "correct" MA85x vs 1N4148/1N9401. The BAS33-TAP also sound a little more like the BA282's.
I hate the Paragon at 18v, sounds like ass to me in that setting. Which is why I've removed the charge pump in all my Paragon builds.
Having said that, I don't think any of my Paragon's are very "true to the original" with the mod's I've done. My versions are all high gain and I actually do like the hard clippers on but gain backed off.
I went through that "everything must be 18v" phase, but in my defense it kind of made sense to have higher headroom on bass.
Some dirt-circuits still sound better to me at 18v, on bass...
So long as your caps are rated, don't let anyone tell you what sounds good to you.
ok I gave it a quick try (without the vodka). Nothing to write home about.
Not worth recording.
The LED's clip later, as expected and are less compressed sounding, as expected. Kind of "nueters" the pedal imo.
I didn't measure the vf of the led's but I'm pretty sure I got these from Tayda. 3mm red diffused.
So you're saying I should pull the charge pump out of my paragon? I don't think I've ever cared for a pedal at 18v 🤔
Well *I* like it a whole lot better at 9v. But there are other pedals that prefer at 18v. Secret Preamp and as I discovered yesterday, the Lone King overdrive. Changed the whole nature of the pedal for me. Also, if you've got the components rated at 25v you can always run the pedal at 18v w/o the charge pump. More options that way.
It looks very fine!
Thanks!
I ordered the diodes from pedal hacker.... he listed them as subs for the OG ones.....
What I'm saying is I need green or amber LEDs in the Paragon that I should order before Robert has a chance to neuter the PCB's 18v...
