(FD) BRAIN BOMB
Fuzzonaut
5.00 star(s)
This one is from the chaps at Fuzzdog, it's based on the Seppuku Mind Warp and they called their PCB Brain Bomb, so I went with that name, after stumbling over a Melvins gig poster that seemed to have a fitting image I could partially "borrow".
There's a PT2399 in there, it's avertised as a vibrato/chorus with a twist, which is giving you all sorts of lovely warbly sounds.
I really dig it, it's very cool on fretless.
Hey do you happen to remember how the blended clean signal was/is for you? For me it seems to boost and warm up the signal a bit too much, I wonder if I messed something up or if that's just something it does (or maybe 2N5088 tolerance could affect it)?
The one time I don't socket the transistors...
I think I was pretty happy with the blend, at least I don't remember not being happy with it. But I haven't played it for a while, so I'll try not to forget to plug it in again to double check. It's in the Doom Room though, not at home, so that might take a few days.
Also, I'm using it on bass, so "boost and warm up" are things I generally like on blended clean signals.
This is one of my favorite modulation circuits from SeppukuFX that you can get a clone of. Not quite as weird as Cassette or Memory Loss but loads more usable. Awesome job on the graphics.
What a doom room? It has to have a goat pen...?
A room for doom. 🤘
@Fama there sure is that boost on the clean signal, but I wouldn't say it's too much, at least not for my taste. And I prefer to keep it pretty wet anyway, like 80:20 or so. A master volume would be fine though.
Or maybe you could play around with R4 (and/or R2) to get less boost? I'm no smart enough to know if that would actually help ....
A room for doom. 🤘
Thanks for checking! It's probably more of an issue for guitar, it can be pretty noticeable for me. I found some FSB (I think) thread with a partial schematic, and it seems R2 was 470k and 390k in parallel, so the end result would be more like 213k. Not sure if Fuzzdog made a mistake or traced a different unit, I got the impression that the Seppuku units were not necessarily of the highest standard - small pedal manufacturers were much less organized back then.
So I might at least test soldering in another resistor in parallel, that feels like an easier solution to me than switching it out. Maybe I can rig it up so that I can try it out first before I solder it in.
