In my BJT
addiction collecting almost specifically for the Super-Fuzz, these are ones that measure around 100 and below on my T7 and have been used in my Super-Fuzz builds:
part num | type | mat | min | mostly | max |
A5T2243 | NPN | Si | 30 | 50 | 70 |
2N2369A | NPN | Si | 30 | 90 | 90 |
MPS3394 | NPN | Si | 60 | 70 | 90 |
MPS4274 | NPN | Si | 70 | | 90 |
MPS6512 | NPN | Si | 30 | 50-80 | 90 |
2N2369A | NPN | Si | 60 | 90 | 100 |
MPS5131 | NPN | Si | 20 | | 100 |
Occasionally I'll get lucky with NOS 2N3903s, but the ones I have still hover over 100.
If you want some unsolicited combinations I've tried and a one-word comment
Q1—Q3 should have the highest current gain (anywhere from 140-200 is approximately OE); some builds suggest these be in descending order of gain.
Q4 & Q5 are sort of the """secret""" to this pedal's tone, and are typically matched as closely as possible (anywhere from 60-140). However, the bias trimmer is meant for you to tune them to get the desired effect (more on that later).
Q6 should be as low as possible, around 50 being typical for original units. Some older silicon can get down this low (e.g. MPS3394, 5AT2243) but you can piggyback if necessary/desired.
Your project schematic might be drawn differently, so your mileage may vary.
