Weird LED issue making pedal non-functional
fuzz
I am using a Love my Switches switch PCB, and a prewired LED w/ resistor. My last pedal, I ran a wire from the dc jack 9v and ground to the respective solder points on the switch PCB, and everything works. My most recent build, a Bellum MK ii, when I do the same thing, the pedal doesnt work. I get no bypass, no powered signal but the LED works. The minute I remove the wires running from the DC jack to the switch pcb 9v/Gr it works. I have no clue whats happening.
Maybe you soldered to the wrong side of the daughterboard?
Hard to tell without pics.
For what it's worth, the indicator led is not a part of the effecting circuit, so [edit for clarity:] if a circuit affects a signal, or a bypass signal is or isn't there--none of these will depend on the indicator led.
Sounds like you are grounding your signal at the switch when you don't mean to.
Check the switch functionality and as Chris said., pcb orientation.
I sorted it out, by removing the switch pcb and just wiring it manually.
I’m clearly not understanding vital element when using a switch PCB. If I use the LED pads on the switch PCB, how do I power the LED? There is an extra 9v/ ground pad, I figured I would just run 9v and ground straight to these from the jack. Clearly that’s not it cause that was the problem. When I removed those wires from the jack to the pads, it worked.
