Ratimus
Hey, I came up with this fuzz that's like a decaying exoskeleton around the beating heart of a Jordan Bosstone. I've added:
- a switchable input boost with a gain of ~15 dB
- a BMP style tone stack with buffered output
- asymmetrical hard clipping via mosfet
- switchable option to run the emitter from what would be Q2 in the original circuit through an LED (for added harmonics) or a 2.2 uF cap (which makes the fuzz gated) or a blend of the two. Lots of harmonic possibilities.
- A voltage starve pot, with the option to starve the just second transistor from the original circuit (changes the sound but doesn't get splatty or disappear) or both transistors (gets weird- may oscillate, octave-down, add an "envelope follower phaser," etc.)
- You can lift Q2 emitter altogether, using the transistor like it's a half-wave rectifier.
It's fun to play around with. My schematic shows a tone bypass but I ended up not using it. I also used a couple different transistors (2n551 for Q1, 2n5401 for Q3).
