Pedal board Output Buffer ?
I built the Skeptical buffer and like it alot ... Does exactly what it says it does imo . ( See pics )
But , i have noticed that Pedal PCB does not have the 29 pedals Oamp pcb ( Yet ... )
So my question is , what would be an alternative to build as an Output buffer pedal to compliment the Skeptical Buffer ??
Thx to Pedal PCB for making great projects !
Hmm.
Well. Buffers are useful. I've never seen the point in using more than one unless one is using a particularly complex board with very long cable runs.
Though it seems to me that the 29 pedals oamp is more of a subtle tone shaper/eq. Which would be where I'd start my search: simple EQ pedals.
I was just looking through some of my PCB boards and i do have a Pedal PCB Transcendence Boost #PCB445 .
And also a Pedal PCB Betty Boost #PCB063
I quite like the ROG "MR. EQ", that'd make a great pairing with a booster of choice, BYOC's has 27db gain... Nevermind.
I just looked at the OAMP, so I see neither of the switches is for tone.
I wonder if the 29 power-section is nicked from Aphex?
Both my Aphex Bass Xciter and Punch Factory do the whole anything-goes power-input:
Bass Xciter
5-12VAC
7-17VDC
Punch Factory
5-32VAC
7-48 VDC
AND even +48V Phantom
Betty Boost seems more versatile, while the Transcendence has a reputation for being pristine ... tough choice. Build both and see!
Maybe try some chip-rolling, see if the Betty Boost is better with Burr-Brown than TL072...
