42TL218RC Audio Transformer question
alienas
Hello,
do some one know the average loss in decibel ou percent between input and output, at 1kHz for instance?
Thank you very much...
Assuming I plug it like in the neurocyton or british royalty. Is there an attenuation (I guess there is) in voltage swing between the primary and the secondary? I would like to put it between 2 gain stages with preamp tubes like 12AX7 in a clean channel to try...
so approx 3db of loss in the 300-3400 Hz range ? OK, it's fine...
Thank you
