DIY Direct Box?
I don't have the Unagi Magnetics website set up yet, but you can pick transformers up together with a D.I. daughter board on the Conspiracy to Commit Electronics website here, just select "XLR DI w/ Transformer" from the dropdown.
I have a datasheet for the transformer that I put together, but I haven't formalized it and posted it anywhere yet.
I guess I should probably add that to the disclaimer on my signature, owner of Sushi Box FX, Conspiracy to Commit Electronics, and now also Unagi Magnetics.
Cool, looking forward to seeing that datasheet and more info on applications as you get to it.
A schematic for active DI was put on FSB a few days ago: link. Even a vero layout was posted for it. Seems easy enough to build. Only took a quick glance, though.
Excellent, thank you! I’ll check it out for sure. The goal is to build a nice passive DI and an active box (for acoustic instruments with passive transducers). It’d be great to have one switchable box, but I think that’s a little beyond me…
Very cool.
I have the old layout from a Countryman DI, but it requires a transformer.
I might just build yours instead since all the parts look common and inexpensive. Thanks for posting it!
Very cool.
Would you mind sharing the layout for the Countryman? Those are great DIs! Active or Passive?
Very cool.
would also be interested.
got a Jensen JT-DB-E i’ve been sitting on for a few years . need a good circuit for it
It's the good 'ol "country hick" project that's been online since 2004 (!!).
I found some modifications on free stompboxes and elsewhere online. When I built one in 2012, I used an inexpensive OEP A262A2E transformer.
The original tracer removed the phantom-powered circuitry and posted a battery-powered version. But I wanted mine to work on phantom power, so I stuck some 37k resistors on pins 2 and 3 of the XLR and ran the other ends of the resistors to the positive rail. Amazingly enough, that worked, and it delivers 10vDC when phantom power is applied.
Excellent, thanks! Hmm I don't etch my own boards or anything, so I'll look around and see if anyone's done this on Vero...
I actually like dual-9v DI operation (VERY little draw), so hopefully I can find a pretty straightforward version of the Hick to build!
I could lay out a PCB pretty quickly, but I don't know how many people would be interested in using the OEP transformer. I think they're only for sale in the UK. What transformer are you planning to use?
I think Niki from N-Audio laid out the original circuit board for the OEP.
Here's how mine turned out. I'll probably leave off the amp source switch if I build another.
Whoa! Very nice!
Like I had mentioned, I'd ideally set it up for 2x9v battery operation rather than phantom, although I realize that may seem silly. Both would be great, but I'm not sure that's possible...
I'll (hopefully) be using a transformer from @vigilante398, but I can't give you specifics of it I'm afraid... It's a Unagi Magnetics E4305 DI transformer.
So- since the Countryman 85 has a transformer, can it be used as a passive box as well? Kind of like the Warm Audio active/passive box?
No, the Countryman always needs voltage to drive the fet. The transformer is just a 2:1 ratio.
The Unagi Magnetics E4305 (I'm guessing) is probably a higher-quality transformer since it's $62 compared to the $16 of the OEP clone, the Vigortronix VTX-101-002.
I'll still build another cheap country hick because I still have a leftover self-etched board, but I'll always wonder if it sounds noticeably worse than a higher-quality transformer. :) It's OK. I have a recording project underway and I'd rather be recording than fretting about sound quality.
Let us know how the Unagi works out.
Gotcha. As much as I'd love a 2-in-1 I think I'll wind up with both a passive and an active once I land on the right layouts.
In thinking about it, aside from a DI what I really need is a preamp for passive acoustic transducer piezos. The K&K Pure Preamp seems to be fairly simple and (should be) a good match for most of my passive instruments. I like that it runs on a battery, too. The only schematic I could find was on this Youtube video. In the comments someone mentions that their schematic swaps the Bass and Treble controls - I wonder if it's just the LABELS for Bass and Treble that are swapped, and not any components..? Below are some images from the vid.
I haven't plotted perfboard or vero from schematics yet, so this is kind of a big project for me. I have no idea where to start, honestly. To complicate things, I also have an excellent transformer-based DI/XLR module (by local saint @vigilante398!) that I'd love to incorporate. It would be nice to have a box that was a K&K preamp > passive transformer-based DI all in one, with the option to switch out the preamp and just have a passive DI.
Is this crazy? If not, I could really use some advice!
