SOLVED Low Tide (help to solve power supply noise)
Pietro
So finally I decided to build this wonderful pedal. I adjusted the trim pots for the BBD and the LPG, I also enclosed everything in its Hammond box. If I connect the pedal to a 9V battery, it works perfectly fine, actually it works better than the original, with less noise as well! Every control knob does what it is supposed to do (I had an original Shallow Water pedal). The input signal is undistorted and clear, the filter opens and close as it should.
Now the problem, as soon as I connect a 9V power supply the trouble start, I can hear a constant high pitch noise, like a sine wave at 2-3 kHz, it seems to change according to the power supply I use, that's why I believe it's caused by the ripple of the power supply. The noise has the following characteristics:
  • The intensity of the high pitch noise is constant and independent of the pedal Volume, I can turn the volume fully anticlockwise and it's still there with the same intensity.
  • With the switch in bypass mode it disappears.
  • The noise seems to be modulated by the LPG circuit. For example, if I turn the Depth all the way anticlockwise, it becomes constant without fluctuations in pitch and intensity, if I increase the Depth, then it starts to follow the modulation.
  • The noise is still there if I turn the Mix knob fully dry or fully wet. Like the Volume knob the Mix doesn't seem to affect the noise at all.
  • Everything still working perfectly fine, I just hear that annoying and constant little squealing sound.
  • As I said before with a 9V battery the noise completely disappears and the pedal works perfectly fine.
  • I noticed that when I connect a power supply or a 9V battery to the pedal after it has been disconnected for a while, the LED lights up for a fraction of a second, in spite of the pedal being in bypass mode. After I connect it, this doesn't happen anymore and the LED works as it should. Probably this is not related to the noise, but it seems a strange behaviour.
Before I start to take everything apart and examine every single part of the circuit, is there anyone that experienced this before and can point me to the right direction to solve the problem? I would really appreciate any help or suggestions.
Please note that I covered the usual suspects already, it's not a mains socket problem, or an amp problem, or a ground loop problem, I tried different setups and the noise is always there no matter what, literally every single pedal I have, from simple analog ones to more complicated digital ones work perfectly fine without any noise. Also I tried several different powers supplies.
Thanks!
Do you have any cold solder joints to the power filtering caps? C16 and 32. Can you upload pictures of the solder side and top side of the board.
This is due to how the anti-pop LED switching circuit works and is normal.
I checked and it seems to be fine, I also replaced C32 since this should be the main filter for the power supply? I admit it I could solder better, but I am improving...damn it would be so perfect if it wasn't for the sneaky squealy sound! Thanks for the help, please see pictures below
If the filter capacitor is good and you're only having noise issues when powering from a power supply then the issue is likely the power supplies.
You could have clock / BBD noise bleeding into the audio path but that would happen on battery power as well, unless it's heterodyning with the switching frequency of your power supply.
I tried all the power supplies I had, 7 to be precise, connected in different sockets, also tried with a power supply and a battery powered preamp and headphones, still the same problem, also a few of these power supplies were perfectly fine with the original Shallow Water I had. It is frustrating :)
On battery works so well, I can barely hear the classic BBD noise when the filter fully opens up, on the previous original Shallow Water I had, the noise was massive, I returned the unit for that reason.
I know you said you already ruled out the wall mains being the issue, but are you able to plug it in at a friend’s house or somewhere else, just to see if it behaves any differently?
mmmh no I didn't try in another house, but I tried in different plugs and also with an battery powered amp to rule out any ground loop, also any other pedal I have works fine. This is not the usual ground loop problem it's a pretty clear sine waveish high pitch sound, I've heard it before in faulty pedals.
Try this one at a time, in this order, and see if the noise stops... do not reinstall each IC as you progress forward.
Remove the microcontroller (ATTINY IC), check for noise.
Remove the V3207D, check for noise.
Remove the CD4046, check for noise.
No difference, the noise is still there loud and clear...thanks for the suggestion, does this points toward another direction?
This is why I love troubleshooting threads.
'When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.'
Sorry, I think I didn't clarify here, the problem is not the power supply, it is still the pedal, there is some grounding problem that passes the noise from the power supply to the output of the pedal, it's not possible that all the power supplies I have are faulty, and it's not possible that all the pedals I have, perfectly work with no noise whatsoever and then that one pedal (the Low Tide) is the only one that it can't take all the power supplies.
So, unfortunately, I can't figure out the problem, but the problem is still there and it's because I did a mistake somewhere, the circuit is quite complex
It sounds like it's what other people have been pointing you towards, which is something in the power section.
Let's recap: since unwanted noise is not present when hooked up to a 9V DC battery--I assume that you are running the battery in through the 9V jack ends-- this shouldn't be functionally different than the many 9V power cables you have plugged in since they are all DC power, so it logically has to be something around or before the 9V in jack. [edit: in fact, maybe none of the previous troubleshooting should have been necessary since none of it would have made a difference to whether it was a 9V battery or a 9V cable.]
I can only think of two things, your mains circuits and in-wall electrical potpourri causing problems, or the 9V jack itself and/or connections. You could solder in another 9V jack to see if it works, as well as inspect and touch up all solder points in those places. This is what solved things when it happened to me.
If that doesn't work, it's time to break out ye olde audio probe.
I found the problem and I can't believe it, there is nothing wrong with my build!
I tried 6!!! different pedal power supplies, different manufacturers (some of them expensive), all with zero problems whatsoever with 10 different pedals from analog to digital.
Then, since the good people in the forum here kept pointing to the power supply or the mains and nothing in the pedal, I dug up my isolated power supply distribution box for my pedal board as last test, I didn't try this earlier because I recently moved in a new house and it was packed in a box full of other stuff. I connected up everything, and boom, no pitch noise whatsoever!
I can't believe I am the only person experiencing this, how is it possible that all those power supplies are not compatible with this pedal!
Hours and hours of soldering, desoldering checking resistors values and there was absolutely nothing wrong with the build!
Oh well in the end the problem is solved.
Thanks everybody for trying to help me, silly me, lesson learned.
