So finally I decided to build this wonderful pedal. I adjusted the trim pots for the BBD and the LPG, I also enclosed everything in its Hammond box. If I connect the pedal to a 9V battery, it works perfectly fine, actually it works better than the original, with less noise as well! Every control knob does what it is supposed to do (I had an original Shallow Water pedal). The input signal is undistorted and clear, the filter opens and close as it should.
Now the problem, as soon as I connect a 9V power supply the trouble start, I can hear a constant high pitch noise, like a sine wave at 2-3 kHz, it seems to change according to the power supply I use, that's why I believe it's caused by the ripple of the power supply. The noise has the following characteristics:
Please note that I covered the usual suspects already, it's not a mains socket problem, or an amp problem, or a ground loop problem, I tried different setups and the noise is always there no matter what, literally every single pedal I have, from simple analog ones to more complicated digital ones work perfectly fine without any noise. Also I tried several different powers supplies.
Thanks!
- The intensity of the high pitch noise is constant and independent of the pedal Volume, I can turn the volume fully anticlockwise and it's still there with the same intensity.
- With the switch in bypass mode it disappears.
- The noise seems to be modulated by the LPG circuit. For example, if I turn the Depth all the way anticlockwise, it becomes constant without fluctuations in pitch and intensity, if I increase the Depth, then it starts to follow the modulation.
- The noise is still there if I turn the Mix knob fully dry or fully wet. Like the Volume knob the Mix doesn't seem to affect the noise at all.
- Everything still working perfectly fine, I just hear that annoying and constant little squealing sound.
- As I said before with a 9V battery the noise completely disappears and the pedal works perfectly fine.
- I noticed that when I connect a power supply or a 9V battery to the pedal after it has been disconnected for a while, the LED lights up for a fraction of a second, in spite of the pedal being in bypass mode. After I connect it, this doesn't happen anymore and the LED works as it should. Probably this is not related to the noise, but it seems a strange behaviour.
Thanks!
