Sandspur Fuzz biasing
apm588
Hi everyone,
Kind of a dumb question. I am starting a sandspur fuzz build and I was wondering how to "bias" it. I know there are two internal trim pots but was hoping someone could walk me through how to bias them with a multimeter. Specifically
1. Where do I put my multimeter poles on the circuit, and what values should I be biasing each towards?
Any help would be greatly appreciated. Thank you.
On my build, I made the "clean" trim pot into an external control to work with different pickups. You're meant to use your guitar's volume control for that, but this helps if you use extra hot humbuckers, like I do.
That mod is offered for $25 on the real ones. This picture is from a nearly 300 page thread, but you can find the mod option on the official order page.
"Bias" is easy and that section is meant to be constantly adjusted to taste by the "Sun Dial it's in series with.
While you usually set and forget it on these type of pedals, the feature here is being able to to constantly adjust those controls to change character.
