Maxon ad9 (re-house in wah(kinda)) mess
Happy belated new years.
My buddy asks if I could "take a look at" his Delay pedal. "My buddy threw it in a wah shell years back" he says. Right then, I should’ve thought about it a little more, and briefly dismissed the idea. But no, I went ahead and accepted it. I was handed what felt like a wah enclosure and without looking at it, set it on the shelf till I left. I get home and pull the cover off this is what I see. So I look into it and try to find some documentation. I am going to have to pretty much restart from Ground Zero. Remove all the wires with the insulation burns and figure out a proper way to mount these two pots securely,etc.
my neighbor also added i also tried to adjust the tiny little pots inside, but it got worse when i did. And I really don’t remember where they were.”
So a simple re-bias changed into a project. But, it is what it is...
My question for you fine folks:
Looking at the schematic, from the factory that unit came with a delay level of 10K, a repeat of 20K, and delay time of 10k(pots not trimmers).
1: Is there any reason that the delay level would want to have been changed to a 250K?
2: What about the 100K that is on the rack and pinion(treadle) that came from the factory as a 10k?
I should change back to OEM values right? I guess I need some reassurance
Thank you very much! I don’t do this for a living. I’m a diesel technician. But I hate, and I mean absolutely hate following other technicians that have done these kind of jobs. There’s a special place in hell for people that do this just like there is for people that use wire nuts on vehicles.
Are there any parallel resistors to the potentiometers? That would allow the use of non-standard pots. I can imagine a hack thinking 250k would give "more" delay, though. Lots of burned pads as well. Still, I'll bet it's repairable. Needs a good scrubbin'!
