Delay in wah enclosure?
mboyd43
Sketching out a project for a buddy who wants a 3 knob delay in a wah enclosure. I've yet to build anything in a wah case, but that part seems easy enough. We were wondering if we should make the repeats or the time controlled by the treadle, then thought what if we could have both options? Currently I'm thinking have 3 knobs on the side, and 2 3PDT flip on-on's wired between a dual gang pot on the treadle and the time and repeat knobs. Both switches down=3 pots in use, treadle does nothing. 1 switch up=that function controlled by treadle. Both switches up could be unusable or get into wacky chaos sounds, either would be neat. Any thoughts on this? Thanks
I put an FV-1 delay in a wah enclosure for a sort of Tom Scholz Hyperspace kind of thing.
Pressing down the treadle decreased the delay time while simultaneously increasing feedback.
I've also put a through-zero flanger (technically two very short delays) in a wah enclosure where the treadle manually swept the flange for that Cherub Rock lead tone.
(Awful recording, but serves the purpose)
View attachment CherubTZF.mp3
I’ve thought about this before, specifically with the intent of emulating Tom Scholz’s infamous Hyperspace device that he used to do those crazy pick scrape sounds with Boston.
I planned to maybe do a dual gang pot that controls CVs that can be set to the 3 pot inputs of an FV-1 delay. One gang of the pot would have a CV that increases as the treadle moves forward while the other gang would decrease a CV as the treadle moves forward. Each parameter would use a dpdt on-on-on configured as a sp3t to select either of the CV sources or a static rotary pot mounted on the side, much like DeadEnd FX used in the Tresonator project.
Feedback and mix (would need an active mixing stage to control it with CV— or just an algorithm with a digital mix control) sweeping up while delay time sweeps down would be sorta a classic hyperspace sound. Mix and feedback sweeping up with a static short delay time would be great for swelling in 100% wet post-punky sounds. Delay time sweeping up with feedback swelling down might be cool for going from a slap back to a stopped-tape pitch slowdown thing.
Where's the rest of that recording?!?! 👹🤘
View attachment 85285 fall guys
Your explanation is what I was waiting for, can I ask you a few more questions?
Can you talk more about the Hyperspace pedal and what you did to create it? I’ve been looking for a way to somewhat replicate that effect for a while. I remember seeing somewhere that Tom used an old echoplex with a modded volume pedal that went up & down and also side to side to control two different things at the same time which seems pretty crazy. 😂
Somebody on the forum recently mentioned the Cooper Time Cube 🤔...
Here's the COPPER TIME CUBE...
BUT WAIT, THERE'S MORE PEOPLE GETTING HOSED!
Does that idea not reverberate within you?
Did you finish the project? Can you show me an audio when you use it?
