Fizz
Newb question: Just curious what the difference would be and why you recommend tantalum?I recommend tantalum for C11...
I forget where I read it - maybe it was here! - but apparently the reason Paul C made the VREF voltage splitters asymmetrical was to help guys using batteries which were running low on voltage.
Smells more like rumor than fact to me. Cochrane is not the only one to offset Vref. Look at the series of BE-OD / Dirty Shirley pedals.I forget where I read it - maybe it was here! - but apparently the reason Paul C made the VREF voltage splitters asymmetrical was to help guys using batteries which were running low on voltage.
It's purpose is to smooth out the sweep at the bottom end of rotation, from 0 to 3.@Chuck D. Bones, what is the purpose of R9? In the most recent schematic it's 470k parallel with the C500k treble pot and R7/7k5, and in the earlier schematic, it's 100k parallel with the C100k treble pot and R7/1k5.
Yes, you can do that if you want to, but the sweep won't be as smooth at the bottom end....in the newer schematic, could you drop R9 and use a C250k pot (or in the older schematic, drop R9 and use a C50k)?
Just reporting in that I went with the version that has the volume moved back into the middle of the circuit with various component changes. Its works and is a lovely pedal/design indeed. Breadboard had me vexed for a while but finally slowed down and got it. It's quite responsive and has the OD capability I was hoping for and still can do the transparent thing as well. Chuck thanks for the encouragement and insights. Now to getting this into an enclosure. If any have this variety of design board and is avail for purchase, please let me know. I really dig this pedal.Matt, any chance you have another board? I have my breadboard almost worked out and would love to build this.
Best Ange
