M matmonster58 Active member Jan 18, 2024 #1 Looking for a lambchop template. I couldn't really find templates for any 1590BB pedals
M matmonster58 Active member Jan 18, 2024 #2 Here's my best crack at it but I haven't made a template before Tayda Electronics Drill Tayda Electronics Drill Designer for custom enclosures. drill.taydakits.com
J JasonWickersham Active member Jun 21, 2025 #3 matmonster58 said: Here's my best crack at it but I haven't made a template before Tayda Electronics Drill Tayda Electronics Drill Designer for custom enclosures. drill.taydakits.com Click to expand... Have you been able to validate this drill template?
M matmonster58 Active member Jun 21, 2025 #4 Yes, I've made two off this template. Make sure to put your led hole in
J JasonWickersham Active member Jun 21, 2025 #5 matmonster58 said: Yes, I've made two off this template. Make sure to put your led hole in Click to expand... Thank you, I just saved it to my dashboard, and did just that. Did a little adjustment on the LED position to use one of the Switch + LED breakout boards, and swapped over to a BB2/BBS enclosure.
