Lowballer/Bassballs AC Ripple Issue
rickdiculous
I’ve now built two Lowballer (Bassballs) boards from PedalPCB and both have failed in exactly the same way. Instead of passing audio, I just get hum, and when I check VREF it has about one to two volts of AC ripple riding on it. This happens whether I power it from a wall wart or a battery, so it’s not coming from the supply. If I clamp VREF to ground with a 1 kΩ resistor, the ripple disappears completely and things quiet down, but of course that drags the DC reference down toward zero and nothing biases correctly.
To troubleshoot, I’ve already tried dropping the divider from the stock 47k/47k to 10k/10k, I’ve swapped the VREF cap up from 10 µF to 100 µF and even larger, I’ve paralleled in ceramics, and I’ve added local decoupling at the op-amp area. I’ve pulled the op-amps out entirely to rule out oscillation, and the ripple is still there. Grounds all show continuity to the jack sleeves, the diodes and resistors all check out, and nothing looks mis-stuffed. I’ve also compared this against Aion PCBs I’ve built with the same parts, and those work flawlessly, so the issue doesn’t seem to be my build technique or component choice.
At this point it feels like the PCB’s VREF implementation is just too high-impedance or has a poor return path, because the behavior matches a floating reference. The fact that the 1 kΩ clamp kills the ripple instantly seems like the smoking gun. Has anyone else run into this on PedalPCB boards, and if so, is there a known fix? Should I be looking at bodging in an external VREF (like a little daughter divider with heavy filtering or a TLE2426 rail splitter), or is there a simpler jumper/trace tweak that others have used successfully?
I'm not aware of anyone having issues with this one.
The VREF path is pretty simple to follow. Red trace is on bottom, Blue trace is on top.
There's really only a few things that could possibly go wrong. I'm not sure how the PCB itself could generate AC ripple, especially with the active components removed.
Any chance you have the wrong value installed for R101? That should be 47R (47 ohms), not 47K.
It hits pin 3 on the bottom opamp too, I think. Even before I populated the whole board, just the power section had this problem. Even when battery powered. Makes no sense to me.
Watching. The dist switch on mine does bupkis, and just isn't cutting the mustard. I'll troll in the background for awhile longer, maybe there's a magic to this board he and I ain't getting yet.
