Third Man x JHS troika delay?
CheapSuitG
The TubeSchemer
This was released today.
Interesting concept, could be useful for recording. I’m a Jack White fan boy and will probably get it.
No 48v phantom which I assume is for cost savings.
Thoughts?
Just watched the full video.
Some glaring mistakes IMO, can be modded but design fail.
Internal switches for mic/instrument, reverb tails on/off and gain.
Ooof.
Eh, kinda neat. Seems like a decent unit for when you want delay on a mic without the hassle of doing vocal effects chain with line/instrument converters or a Pigtronix Keymaster. While it’s not the most exciting thing ever, I’d build one if Robert release a PCB for it just so I can have quick access to delay for when I mic up my talkbox
"The bypass switch is above the sliders to keep it out of the way of on-the-fly adjusting."
Not because the footswitch wouldn't fit at the bottom of that enclosure? Doesn't look terribly ergonomic to me!
Saw a band (The Wameki) last night where the vocalist just plugged a mic into a guitar delay pedal. It worked fine and they rocked harder and were more punk than Jack White ever did or was. Although, FWIW, I'd build a PPCB that had the same concept, because singers that move around a lot would probably benefit from a low profile, low complexity pedal situation.
I think the taptempo/oscillation switch in my DOD Rubberneck would be enough control for vocals as well.
Maybe the tempo switch (Rubbernecking) would be fun as well.
