folkcultural
I think so too.this ... whether it is a kit, a reissue, or a surfybear. I'm not opposed to digital, currently have the rv-6 for that and I wouldn't kick a soft focus out of bed if I could find the right deal on one.
Anybody try building a standalone reverb tank for a build? My amps don't have built in reverb.
Grab an abe fx IC, very nice plate verb.Ive never loved any of the diy reverbs. Though i havent tried the spatialist, the fv-1 ones are meh to me. And the belton as well. I do have two amps with true tube spring though and thats what i’m comparing that to. I have a boss rv-200 for the other stuff, and in my experience digital reverbs are better not diy. By the time you build an fv-1 reverb you’re nearly at the cost of used rv-6.
That said i do like the spirit box and hydra, as options if you’re going for some “different” reverb options
So I've been looking into using the BJT-MOODY driver or the SG-Riptide driver for...
... a DIY PLATE REVERB.
As with all my fun ideas, somebody's beaten a path before me:
If interested in plate-verb, there's a lot of info online about fabbing up your own plate-reverb.
There's also this https://hackaday.com/2018/11/29/build-a-plate-reverb-from-ikea/Meeeeeee toooooo. Love plate. I've toyed with this too. Whoever gets there first start a thread up![]()
+1The Neunaber algos are really top notch. Like a Briscasti M7 in a pedal. Really hifi and detailed.
I don't think any DIY rev could complete, heard some PT2399 and FV1 based pedal and there is simply no competition
https://griffineffects.com/byo-pcbs/modulation/ricochet-pcb
I've been eyeing this. Anyone tried it?
EDIT: There's some threads here on it. Looks like there is a problem with a resistor not being the correct value in the doc
There's always the https://scientificguitarist.wixsite.com/home/disappearing-act, although "easily swap in different tanks" only works if you pick tanks of the correct impedance - although I think that restriction applies for other options too.Does anybody make a general purpose reverb driver PCB, along these lines?
This one looks cool but it’s full kit only, Swedish, and their American distributor is out of stock.
Would be cool to have a pedal where you could easily swap in different spring tanks.
*edit*
just noticed it was mentioned earlier in the thread. So where the PPCB board already?!
I need to make my experimental, exposed-spring, “I can’t afford an Ekdahl Moisturizer” monstrosity!
That one definitely sounds cool based on the description (i.e. clean note attack with the reverb coming in at the end). I haven’t made it to the ‘get my own PCBs made’ phase of DIY, yet. But if somebody did get a batch of these made up, I’d definitely buy a board or two.There's always the https://scientificguitarist.wixsite.com/home/disappearing-act…
The ducking is on a control, so you can just turn that off and it's a normal spring reverb, too. But if you use it subtly it can help improve legibility, while the reverb still sounds just as big.That one definitely sounds cool based on the description (i.e. clean note attack with the reverb coming in at the end). I haven’t made it to the ‘get my own PCBs made’ phase of DIY, yet. But if somebody did get a batch of these made up, I’d definitely buy a board or two.
Alas, I’m in Texas, which is about as non-EU as you can get!If you're in the EU I can ship you a PCB or two.
