Lytt Effects
EDIT: SOLUTION - incorrect part was ordered for the relay. This board requires a 5v latching relay (EA2-5SNJ), but I accidentally ordered and installed the EA2-24NU, which is a 24v latching relay. Moral of the story is: triple check your part numbers when ordering, and always use sockets.
Ok y’all, need help with my first go at a relay bypass. I am using it with the Informant PCB (1981 DRV) and have it wired up in buffered bypass (In Jack to PCB In > BP to Relay In). The LED is switching on/off as normal, but the effect stays on no matter what.
So far, I have ensured all components on the relay bypass board are the correct value, orientation, etc. but please double check me. I also triple checked the 3904/3906 locations. I also swapped in a different relay to no avail.
Many pictures:
Many pictures:
